1 - 9 of 9 Posts
hi
i got brembo rcs19 master cylinder and goodridge stainless steal lines. looks like double banjo bolt which came with mc is too long. what should i do ? what should be a propper size of the bolt to make it work ? can i put an extra washer in the middle ? does anyone else had the same problem ?
thanks
any other good ideas ?
it's not that the bolt is too long, it's that the banjo's are too thin. What you need to do is put two washers at the MC. Did this with mine, no issues.
The bolt that comes with the RCS is 30mm long and if you have the Goodridge brake lines you should get the 28mm long bolt.OPP or Hardracing sells them.
1 - 9 of 9 Posts
