1 - 12 of 12 Posts
Hi Everyone,
Just wondering if anyone has tried using a hydraulic clutch setup on the 10R? I find the clutch a lot heavier than the '06 R6 and Gixer 750. It's not a must have mod, but the idea of a lighter pull definately is tempting. Has anyone tried a hydraulic clutch before?
I found this link for Ducati's and wonder if the Brembo unit can be fitted onto an '07.
1. http://www.ducatimeccanica.com/MMC/clutch_conversion.html Duc Kit
2. http://www.redracingparts.com/en/english.htm#english/motorbikesmotorcycles/productsandcomponents/brakesclutchesoilfluidreservoirs.php Some Brembo radial pumps
Did a search, and didn't find anything on the subject. Any info would be appreciated. Thanks in advance.
MSR clutch mod
Get the MSR universal clutch perch/lever cheap $35 and lowers the lever pull alot.Hell tommy hayden ran it last year and so did the wsbk boy's.
Any pics of the msr clutch lever?
I guess I have weak hands because I get tired of holding in the clutch at long lights and end up shifting to neutral. Is there a different perch that pazzo levers would work with? I know magura makes hydraulic clutch kits for fourwheelers.
My 05 blade has HC. Doesn't make it really easier to hold. Test ride a Fireblade to see if that sort of clutch setup is what you are looking for.
Cheers
1 - 12 of 12 Posts
