1 - 3 of 3 Posts
hi,at the mo i am running brembo calipers on factory 300mm discs on my 2nd gen,i also run the brembo rcs master cylinder with braded lines.
if i bought the brembo 320mm front discs will it improve my braking power much more than now?and what size caliper spacers will i need..cheer's.
ps,are the 320mm clubman brembo discs as good as the 320mm hpk brembo discs??.
I replaced my m/c, disc's and calipers all to Brembo and went with the oversize 320mm floating discs. Stopping is no longer a guessing game as compared to the stock set up.
My spacers are 10mm.
Not sure if the 320mm are that much better then a 300mm set up but I wanted the most stopping power of the two (larger discs typically will have better stopping power but also have a weight disadvantage).
Hope this helps...
1 - 3 of 3 Posts
