1 - 19 of 19 Posts
Got a quick question regarding the brakes on my 07 ZX6. I could have posted this question on Kawi forums but I feel much more confident in this forum for useful info...
When I get on the brakes anywhere over 55-60 mph I get a vibration in the front end until I get down to about 50mph and then it goes away. I can't fully recall if the bike had this problem when I got it (goldfish memory) but I got the bike with 5000 miles on it and it has about 6600 now. It has what I assume to be stock brake pads on it, stock rotors, and a Brembo 19x18 with Spiegler lines. The front tire is also new since I got the bike and it doesn't seem to have any kind of shake outside of braking.
Please help!
If it only vibrates with the brakes applied then it has to be the brakes.Check the rotors you may have one that's warped.
Is there an easy check procedure? I just had it on the stands and tried loosening/tightening everything and I tried tinking the buttons a little bit to free them up if they were bound up in any way.
Its probably time to clean the calipers real good along with the rotors.
A dial indicator for sure.There should be a procedure in the manual if you have one.
Damn, I guess I will have to download the manual..
Your going to have to make a platform for the dial indicator. Put the needle against the rotor and turn the wheel slowly. There should be aa spec for being out of spec. Sometimes a simple loosening of the bolts, fresh loctite (242), and torque to spec can change things. Good luck.
Discussion Starter #8
I guess I am going to take it all apart and redo it... I will visually inspect the rotors then since I don't have the proper tools to check the runout on the rotors... If there's no difference then I will start looking into new rotors.
I always tell people to check the head bearing, I had a problem with the front end pulsating on my 10 and after I changed out everything that had to do with brakes and still had the issue it ended up just being my head bearing!
Did it pulsate when only braking?
Wheelie popper?
Discussion Starter #14
I do wheelies on mine but I'm exceptionally easy on the front end IMO due to my history of stuntriding... ie-I know how to do it right haha. With the mileage on the bike I really hope it's not steering bearing but that would be right in line with my usual luck haha.
Steering bearing's are $35 bucks and only take a couple hours to put in if that, they are actually pretty easy to do!!
I know what you mean.All I can say is Ive been on the track with stock brakes to upgraded brakes and had the lever pull all the way to the bars,Ive never had a pulsation and have had my rotors,pads,and calipers on and off the bike many times.Ive ridden bikes that have and the end result has been a warped rotor or not torqued bolts to the rotors.I guess steering head bearings would be a issue also.I just never had that problem yet.
Discussion Starter #17
I will check the bolt torque. It just blows my mind that a normal person riding on the street could warp a rotor without doing something excessively dumb.
If the rotors have been off the front rim you dont have to do anything excessive to warp them . They may have not been tightened correectly.
Discussion Starter #19
Just an update: I mounted new tires, while the wheel was off I removed the rotors, checked everything and re-installed. Put her all back together and the shake is gone! I guess it was a bad tire after all... either that or something was out of whack and I righted it with all the work.
1 - 19 of 19 Posts
