1 - 7 of 7 Posts
ok guys, so I redid my brakes, swapped the front calipers with the zx14 ones
night and day difference and with some crg shorties and SS Galfer lines the bike stops on a dime
now I have about 5,000 k miles on these pads they are the HH
so I assume I will buy a set of HH pads for a zx14 then since those are the calipers I have
I have a set of new race pads for the zx10, but I would rather not use those carbons as they are well race pads, I want some HH pads
so my question is, where to get some HH zx14 pads, and a good deal, and I dont want to risk it running zx10 pads in zx14 calipers
thx
thx
The zx10 pads won't work.
You can use the 07-08 zx6r pads I was using sbs but switched to ebc and they do pretty good.
The ZX-10 pads will fit after some filing/grinding off of the sides of the metal part. I did exactlt that when I recently did the same switch. Just measure the metal area width of the Nissin caliper pads and then grind down the Tokico pads. This is what the guys from Braketech told me you can do without any problems.
I did it....and no problems whatsoever. The only thing is that the top retainer pad clip thingies wont go on with the ZX-10 pads in the Nissin calipers. But alot of guys don't use the clips anyways.
thx guys you guys rock
how often, after how many miles do you guys change pads, street riding
for street riding I would suggest changing them ever season with the tires depending on how much you ride.
thx buddy, yeah I need to change mine, I have about 8,000 miles on the bike
1 - 7 of 7 Posts
