1 - 6 of 6 Posts
Does not drive into smoke
How often do you change brake fluid in your track bikes? Do you actually experience brake degradation due to a lowered boiling point?
Has anyone switched to DOT5? Just curious...
I usually end up changing fluid about every 10k miles or so. Doesn't seem to impact their performance. But don't use DOT 5 unless your brake system is designed for it.
1 - 6 of 6 Posts
