1 - 3 of 3 Posts
The the brake pad pins stripped, and easy-out isn't working, so I get the idea to just pull the caliper apart and try vise grips on the pin.
What size torx are you supposed to use??? The t40 fits but is floppy, is there some sort of special size I need?
Thinking now about going to get a manual impact to hammer out the pin with an easy out - maybe then it'll bite.
The pins use a 5mm hex wrench for the Gen 3. When you do finally get them out make sure you coat the new one's with anti seize compound to keep this from happening to you again the caliper bolts also will make them a lot easier to remove next time.
1 - 3 of 3 Posts
