Check the fuel pump relay and fuses. disconnect the harness from the pump to see if it is getting power to the pump. Might also be the tip over sensor as well.
:welcome: Trent BTW :welcome:
So, like I said, have you checked the tip-over switch? Farting around with the fuel pump is most likely a futile endeavor. It's embedded in the tank and there's a very slim chance it would be damaged in a fall. But there are other things that power it that could cause it not to work. The tip-over switch, the ECU, the fuel pump relay, the fuse, the clutch safety switch, etc. The ECU will turn the fuel pump on for 4 secs to prime the rails. If you're not even getting that far with it, then you need to forget about the pump itself and figure out why the ECU isn't sending the signal.Bike went down on left side. I tested the voltage where the fuel pump plugs in. It has 3 wires. Black with yellow strip is negative. I get a constant 12 volts on green wire with black strip and nothing on the white wire with red strip. I read somewhere that I should get a 12 volt reading for about 3 seconds, which I imagine is the fuel pump priming. Fuel pump is replaced
The 12 volts constantly at the pump is irrelevant. The pump is activated by switching the ground side, not applying power to it. The relay and ECU switch the ground to complete the circuit and turn the pump on through the power wire you're reading. So, either the ECU is bad or the relay is bad.I can hear the wheel in the tilt switch. I believe it is fine. like I said I am getting a constant 12 volts to the fuel pump on 1 wire. I have check the fuses. all good. I have inpected wiring harness on left side. all good. I disconnected the positive lead to battery to reset ecu. still nothing.
Neither one of these things should be happening. The starter relay clicking means you have low voltage. Try jumpstarting the bike from your car. Just because the battery is showing 12 volts at the terminals doesn't mean it's good. Unless you do a load test on it to see what amperage it's pulling at startup, you don't know the true condition.when I press the ignition I hear a loud clicking from starter relay and a mild clicking from relay box
Don't just go blindly replacing components. Isolate where the problem is and fix that problem. You've already wasted time and energy on the fuel pump itself when that's not your issue.ok well im going to see if I can get a new relay box
