1 - 12 of 12 Posts
What rpm chip should i be using tryed a 12600 and its not shifting...i think its reving to fast. Rev limter is 12800 on the gen1 zx10's right? Im running really aggressive gear so i think i need about a 12400 or 12200 chip?
stock ECU Limiter is 12400, shows higher on tach though but it reads voltage from the ECU.
damn! no wonder then LOL! Ill try a 12200 and go from there
Discussion Starter #8
what type of auto shift are u using and how are u triggering it?
mps kit what do you mean how am i triggering it? i have a thumb switch to early shift if it i need to but with 15/48 gearing i cant keep up with it to shift with the button
mine didnt work good pass 12,200 chip
Gen2 Ripper
Damn, 15/48! 1/8th passes?
Discussion Starter #12
yep same gearing as wetly
1 - 12 of 12 Posts
