1 - 6 of 6 Posts
im having a little trouble when i blip the throttle before the temp hits 180d. it usually happens after the bike sits during the day. i would leave work and when i would blip the throttle it would turn off. over 180d i noticed that it wouldn't turn off. anyone have any ideas of what is going on? fuel filter?
bike has approx. 117,000 miles her.
thanks
Discussion Starter · #3 ·
2012 zx10
Could be your ignition system/spark plugs. Mine started doing that after I installed an exhaust but doubt that's the case for you.
Discussion Starter · #5 ·
Ive changed spark plugs twice, regular maintenance. Still shuts off. Thanks
The Pace
Nice, if I recall, slab miles. Please correct me if I have wrong member in mind. Original engine? If so, has to be the fuel line kinked, flash, fuel pump, or ecu if still used with flash. Something simple. Have to find a tech to sort out the trouble shooting.
If you put those miles on a g4 without a blow up even just doing slab, still good.
1 - 6 of 6 Posts
