1 - 8 of 8 Posts
my bike starts and dies immediatley cannot find the problem !!!!
what i have done
-unplugged powercommander and reconnected stock plugs
-attempted to bypass top tip over sensor)
-switched gas tanks (fuelpump is good)
the bike did not sit and ran fine last time i parked it 2 days ago
when cranking the bike if i twist the throttle it just continously cranks but as soonas i let off of the throttle the bike starts right up but then immediatley dies
Check your ground connection on the battery but might as well check both while you're at it.
Are you sure you don't have any pinched fuel lines? All wires hooked up to the fuel pump?
Let the tank prime like 4 or 5 times...turn the key on, let it prime then turn it off. Repeat and see if that works.
If none of that works I would check the main harness for the ignition and make sure all your coils are seated properly and connected.
1 - 8 of 8 Posts
