1 - 12 of 12 Posts
I want to be able to lift my ZX10R with out supporting it by the swing or under the front forks. Dose any one know of a stand that can be used to lift a ZX10r by the swing arm pivot to unload the suspension? I use to use a soilid rod through the swing arm pivot on my 93 ZX7R, but on the 10 you can only get a 7/16" steel rod through the pivot. Any help?:dontknow:
BD did a stand similar to what you're looking for.
That's where the abbastand is different. It lifts at the center and holds the rear end off the ground. Then you can add the front lift.
1 - 12 of 12 Posts
