1 - 2 of 2 Posts
my oil filter came loose lost all the oil on the highway bike was shut off immediately, filled oil back up new filter bike wouldn’t run I removed power commander bike idles fine now but as soon as you touch the throttle bike dies any ideas? Bike was covered in oil
TPS sensor?
Stator?
Low compression?
'16 ZX-10R KRT
What does it sound like while it's idling? How "immediately" was it actually shutdown? Like, as soon as you noticed the oil pressure light you hit the killswitch and coasted to a stop? Or you noticed the light on, immediately pulled off the road, and then shut it down?
TPS sensor? That only trips if the bike falls over.
Stator? Only used to recharge the battery.
Low compression? Oil problems don't cause low compression. It will spin rod and crank bearings. That's the more likely what happened
1 - 2 of 2 Posts
