1 - 8 of 8 Posts
I have a Gen 3 and suspect my forks are slightly bent.
I found a set of 09 zx6r "Big Piston" forks and triple clamps for $350
Will these interchange onto my Gen 3 and are the "Big piston" forks a real improvement?
Can you swap" Big Piston Fork" into a Gen 2 ZX-10R ?
Keep in mind that changes in overall fork length will alter handling characteristics. Fork from a 6r may not have a desirable spring rate or valving for your setup.
Yes the 6r forks are longer than gen2 forks so you'll have to have 10-15mm of fork above the top triple to get same geometry....you'll have to figure out if the internals are suitable for your weight.
1 - 8 of 8 Posts
