1 - 5 of 5 Posts
Stock, 04 setup is a little thicker or you can buy a couple extras (different part numbers throughout stack) and thicken the height up a little. Also you can use some heavier springs if you like.
OEM is best. :thumbsup:
:iamwithst :eek:ccasion1
Although I do have some Suzuki fibers in for the first couple of fibers right now just to play with the stack a little. Works well but Kawi clutches are 100% better no dout. Don't use aftermarket fibers unless you want to spin a berring or have to drop your pan every couple of races.
1 - 5 of 5 Posts
