1 - 10 of 10 Posts
2015 zx10r
I want to go 17/41 gearing can some one tell me the best brand for sprocket and chain. I’m not to worried about price i jest want it to last longer. Mybe a hybrid rear sprocket thanks
My OEM sprockets and chain lasted longer than anything else I've used.
Longest lasting would be a high quality 525 chain, and steel sprockets. OEM chain is a 525 EK 3D, the alternative to that would be the highest strength 525 DID chain. Steel sprockets are the way to go, most brands are probably good: vortex, superlite, OEM/sunstar. Proper chain slack and maintenance and you should see 30-50k miles out of a set. If you’re drag racing often stepping up to a 530 is probably worth while.
1 - 10 of 10 Posts
