1 - 16 of 16 Posts
After having a issue with my rear brakes on a ride its time to do some braking up grades to my 2012 zx10r.
I have ran Russell stainless lines and ebc pads in the past with just generic DOT4 fluid.
What is everyone's opinion on the best pads lines and fluid to use. I would like to find some lime green lines if anyone has had any good experiences with any particular sets?
EBC HH pads with Speigler lines motul RBF600 dot 4 and Mikey moto rear rotor. It was a big upgrade
I love the Core Moto lines for the gen 4.
Im a fan of the ATE original fluid and the Carbone Lorraine CL Braking XBK pads.
Speigler lines
motul RBF600
Your welcome.
I like the Galfer 1375 pads or the Ferodo xrac or zrac pads and Motul RBF 660 fluid. Zrac are probably over kill unless your racing.
This is my rear brake set-up. Cast Iron Full Floating Ferodo rotor, Agras Hanger, Brembo CNC caliper and Spiegler line. You will never want for better brakes or modulation on the rear of the bike when this is installed and you can get the custom line made in just about any color combination you could want.
The line dimensions are on this page
http://www.rogueracing.org/zx10r/agbrembo.htm
As far as brake fluid is concerned I have tested it all from $100 a bottle Castrol SRF to the Brembo brands to the RBF600 to the $2.99 a bottle Valvoline brand at Autozone. Unless you are endurance racing and literally boiling the fluid out of the calipers which very few people here will ever be capable of doing then the $2.99 a bottle Valvoline stuff works just as good as the $21 a bottle Motul stuff.
Discussion Starter #12
That's a sweet setup!!
Discussion Starter #13
What was the issue you had? I really don't think rear brake setup is as important as your front setup.
How old is your fluid? Pads aren't worn out?
I was riding some pretty tight roads and while coming to a stop head a really loud and low pitch squeaking. After starting again and coming to a stop 100 yards later I had no rear brakes. I pulled another 30 yards across the road to check them out and pulled the bleeder cap off and a bit a fluid misted out. After this I planned to just go home and bleed my brakes and change fluid. After I took off again I had brakes. The bike was new in 2012 and has 9200 miles on it. I think the brake line just got hot and expanded some and got a bit of air in the line.
I also think it was a good idea to blow a little money. I went with a Braking stainless steel race rotor, spiegler lines, rbf600 fluid and ebc hh pads. I'm gonna see how everything does with those pads for now and get some better ones later on as I got myself some carbon fiber goodies too :). Just need motivation to install the mess now.
What do you do with the bike? Personally I use performance friction pads, galfer sbk lines and a brenbo master. Interested to see how the zx10 calipers fare compared to the 09-12 zx6 calipers.
Discussion Starter #15
I do a lot of mountain curves and an occasional track day.
Definitely the lines, a good HH pad (the race pads require heat and if you don't have the heat in them it could make for a bad day) it wouldn't hurt to upgrade the master on the bike to one of the current radials, they are pretty good these days.
1 - 16 of 16 Posts
