1 - 3 of 3 Posts
I was watching Dave Moss's unsprung on www.ustream.tv and he was talking to the CEO of Bazzaz and they mentioned removing the O2 sensor all together after self tuning because it will just continue to self map which isn't good for the piggy back ECU. The way both of them worded their sentences was vary confusing figured i would run it by you gentlmen. have you guys had any problems leaving it in or can you confirm this info?
Thanks
Greg
It might not be good for the o2 sensor to leave it in there since you are putting un-needed mileage on it, but the mapping feature only works if you turn it on and it also only suggests changes, it does not make any changes until you hook up a computer and confirm the changes.
I have it connected most of the time and it's continuously logging,never had a problem.
:dontknow:
I agree though,when you are done tuning it's better to disconnect it...
1 - 3 of 3 Posts
