I've got an 08 that came with a full Akra system and Bazzaz. It seems like it lays down after 10k, like it was out of fuel, so I thought I'd check the map with the autotune that came with it. I installed, beat on the bike a bit, then it told me I needed to add a lot of fuel, like 15-16% in the throttle position/rpm zones I logged. I applied the changes to 8k and above and it seemed to run better. The next couple data capture sessions yielded me no data at all and then I noticed I was getting a "sensor error" on the Bazzaz. Makes sense, no good data means it is smart enough not to record anything for me. So I borrow a sensor from a friend and get the same results. I check all my connections and cable and they appear good. The Bazzaz recognizes the fact that I have the autotune box on and acts like it is going to work, but it doesn't. Any ideas?
