1 - 6 of 6 Posts
Ok I have come down to the last thing to do on my Auto Tune install, and that is connecting a power source. I know that it has to be a switched power source, so I'm thinking of connecting it to the red wire going into the servo motor. Has anyone done this, or is there a better way.
not sure if your using power comander or bazzaz, but my bazzaz instructions said to hook the switched positive wire to the red wire comming out of the taillight plug,
Hi Thanks for the reply. I have a power commander PCV. I hooked it up to the servo wire, only because the wires go all the way down to the battery. I hooked the ground to the battery. I tried it and it works. I just have to setup the auto tune.
does anyone have pics of the 02 sensor installed on the gen 3 stock header,, or any pic of the o2 sensor installed, thinking of doing the auto tune but not sure. Also how doe sthe bike run now that you have installed the auto tune
1 - 6 of 6 Posts
