1 - 4 of 4 Posts
i purchased ASV levers for a 2018 zx10r since there wasn't any specified for a 2019 as of yet. i started to remove the stock brake lever which is a brembo lever/master cylinder and noticed that the stock lever has a screw connecting the lever to the master cylinder. looking at the new ASV lever i do not see any way how this screw can connect to the ASV lever. do i have the wrong ASV lever? doesn't the 2018 zx10r also use a brembo brack system too?
thanks
Yep. The ASV should come with a little plunger that goes into the MC and rides in a slot in the lever.
I was disappointed to see that the ASV design doesn't allow for any adjustability like the stock brembo lever.
Discussion Starter · #3 ·
Once lever nut and bolt are removed, do i just pull the lever from the rubber master cylinder boot?
Yep! Just pull that sucker out. (And keep it with the lever so you don't lose it!)
1 - 4 of 4 Posts
