Ariete Aluminum grips are manufactured using a combination of aerospace grade aluminum and the Italian company’s Supersoft grip material for an unsurpassed feel at the controls. Designed to fit any motorcycle with standard 7/8” bars, Ariete motorcycle grips require no special tools to install. These grips will not rot over time as they are manufactured using a UV resistant compound that provides a unique feel. They’re also surprisingly light and come in your choice of black, gold or clear anodized colors.
Ariete Aluminum grips are not yet available on our website. To order yours, call TJ at 866.931.6644 ext 817 or email us – FORUM at RIDERSDISCOUNT dot COM is the address and be sure to include ARIETE ALU-RUB GRIPS in the subject line along with the color you want and we’ll get back to you right away.
Each grip has a 125mm overall length.
While the grip is secured in the conventional manner over the throttle tube, the clutch side uses two set screws to hold it in place. Ariete even includes the appropriate Allen key for installation.
The inner aluminum piece’s shape is concave to improve comfort.
Supersoft grip compound is slim yet soft to the touch. The diamond profile of each nub grips well rain or shine.
