1 - 10 of 10 Posts
Today i take my bike after installing the rapidbikeiii but the mechanic says me that dynojet and rapidbike not have available and o2 sensor eliminator(lamda eliminator) for my bike. I am surpirises for that, anyone have any idea?
I try at rapidbike site and i found this http://www.rapidbikeusa.com/cgi-bin/shopper.cgi?preadd=action&key=1109KRB3089X
The necessary Rapid Bike Lambda Eliminator/Emulators/RB-02 Modulator for complete “Open Loop” Tuning Mode
Discussion Starter #2
noones have any idea for oxygen sensor eliminator for zx10r 2008? I try found them at greece and dynojet and rapidbike says me not available yet.
Premium Member
Normally, removing a closed-loop function that keeps the engine at a proper air-fuel ratio would be considered a down-grade. Leave it alone.
i conact with dynojet and dusty says me Unfortunately we do not have an eliminator for this model. It is something we are working on but I do no have a release date. Anyone knows about rapidbike o2 sensors?
Hi!
Have you found a o2 eliminator kit yet?
I`m also looking for a 02 eliminator but havent found any.
radio shack sells them. If you can find out he resistance the computer want to see. Buy that Ohm resistor was radioshack adn sonder that puppy in. THat is all a MIL elimenator is. It just comes in a pretty housing.
Thanks but I want something `plug and play`!
Mike at Dynojet sent me this answer ,
`We do not recommend the Powercommander for the European ZX10 because we have no way around the 02 sensor at this time. The PC5 will not adjust anything the 02 sensor controls. `
Must be some hitech unsolvable o2 sensors on the 08 09!!!!:dontknow:
SPLAT!!!
haha, installing a resistor on 2 wires is as plug-and-play as wiring gets, period. That is crazy though this o2 sensor is that much of an issue :dontknow:
Premium Member
Why would you want to replace *correct* air/fuel ratio, as done by the closed-loop O2 sensor and its control system, with an *incorrect* air/fuel ratio caused by going to open loop control??
The closed-loop operation only happens at light to moderate engine load; it's not costing you any power and it's helping with your fuel consumption ...
I put on O2 controllers for the 07 on my 08,seems to work fine.:mrgreen:
I will do a custom map in two weeks and I will try to test with and without O2controllers to see if there is any difference!
1 - 10 of 10 Posts
