1 - 17 of 17 Posts
In this day and age , there should be an led headlight that’s simply plugs in...right ? Please tell me yes
No. LEDs should not be used in this bike. The lens and reflector is not configured for the LED directionality and will scatter the light instead of focusing it where you want it. Besides that, the heatsink on the back of the LED bulb won't fit in the weather tight covers. You have to drill out the covers to fit the heatsink and that exposes them to debris. You can do that and plug in some lights, but they'll look like crap. People will say they "look brighter", but that's due to the color temp and the scatter pattern and not the brightness of the LED bulb. You'll piss off other drivers at night with them because the cutoff pattern and angle of the beam can't be adjusted. If the housing was designed around LED then it would be different.
Ok thank you very much. I will not even consider it Not a big deal anyway. Thank you skydork!
just an FYI... there ARE plug & play LED's that fit inside the weather covers (on gen5 anyway), and include a fan on the back of the bulb assembly to keep it cool. the catch is you need to purchase a model with a short rear section, and also a small controller box, because that has to slide inside the empty area inside the headlight assembly where the wires are. i purchased 3 diff brands of short LEDs, they all fit within the wearther cover, but only 2 out of 3 controller box could slide into the gap between the back of the reflector and the edge of the access hole.
i have these in my 16 zx10r right now and they fit fine.
the cutoff is not as sharp of a line as OEM setups, but its not blasting anyone in the face.. unless you turn the brights on.
its not just the color/kelvin change, there is definitely more light than the factory bulbs had... i frequently ride at night and some of the roads here are nearly pitch black, no street lights... these bulbs helped alot, the distance they can illuminate is better than the stock bulbs.
So those can be used plug and play basically ? Where did you get them from? Make and model?
yes theyre plug and play, just make sure the LED is positioned the right way, the base plate has notch on it that fits into the housing, but it can rotate within that, so make sure the LED blade is vertical, its easy to see from the front when you install them... the only tough part is fitting your damn hands in there to install them and tuck the wires/box in... helps if you have a rear stand to set the bike up straight and then turn the wheel to the side youre working on to get space for your hands, but its basically the exact same as replacing a factory bulb, the only difference is tucking the little relay box in with the wires into the housing gap can be tricky.
Just one listing of many these have improved distribution because of the led configuration
yep theres a lot out there, just keep in mind you need H7, that link is for H11, and has a much deeper back section so i dont think those would fit.
here is the set im currently using... im sure there is much better ones out there if you hunt, but i wanted to try a few different sets without spending too much so i grabbed these for cheap and wasnt worried if they didnt fit, but they work just fine... the key measurements is the back section (from mounting plate to rear of fan housing) and the size of the little electric relay box that is part of the wiring it has to slip inside the headlight housing, the one with this set is very small and fits in without too much hassle, just had to wiggle it around until i got the right angle to slide it into the gap.
i went with the 6500k option btw, i dont like the blueish 5000k lighting... i think 6500k is considered "white"... has a slight blue tint in photos, but IRL while riding it seems like a pure white light.
Well, not really. 6500 Kelvin is pretty blue. Pure white/daylight is in the 5000k range and the lower the value, the more orange it is. 2700k-3000k is like the old incandescent bulbs (warm white). It goes to white the higher you go to 5000k before turning blue above that. I think 6000k is too blue of a tint for headlights, but that's as blue as I'd go myself. Higher than that, it's a very noticeable blue.
444400
444401
I'm still not sure where you found those bulbs you posted about. Those slim H7 bulbs are practically nonexistent that I've found, other than from AliExpress. And the pure Philips LumiLEDS are even more rare. They are knockoffs to the Philips ones. The increased light you're seeing is due to the scatter from the LED bulb, not really the brightness of them. I would be interested to see the specs on those specific bulbs, but I can't find shit on them.
I have those in my G3, fit is good, i had HIDS for years but swapped the out when reducing draw on generator.
Discussion Starter #11
Yeah I’m still not too clear on this topic. I would like a link from a good reputable place like amazon ,for the correct led bulbs but I guess it’s not that simple
you're gonna want to put projectors into the lenses and go lower K not higher, humans see better in a yellower light, 4k range. if you put those bulbs into regular headlights like an asshole i hope you get ticketed as you should. as skydork said already, unfocused hid/led lights are a hazard on the road
The Pace
No reason to dork with these lights unless you MUST ride at night IF the light throws just as hard to sides as ahead. Blind sides are the problem as can't see critters and tumbleweeds or even peds or even cagers without headlights, whatever.
Also consider whether you in fact ride at night at all. Some people want to be seen the whiter brighter and often wider is definitely a + there!
To OP: I have done both. Used HID retrofit projector mod on my Celica, My CBR1000RR and on my truck. On my CBR, I bought a used headlight assembly and pulled the lenses off, removed the reflectors and inserted the kit I bought from K&T. It was tedious and required a lot of work. The lights worked flawlessly and I traded in my bike with those HIDs. On my ZX, I am currently installing Katana LEDs for now until the new HID kit is available. On my Frontier, I used the LED bulbs and the results are very satisfactory. For my Celica and my truck, I did not do any modification except to remove the halogen and installed the LEDs/HIDs. So I would recommend starting with the LEDs. They have to be inserted in a certain way to be effective. If you still don't like it then HID retrofit will be your best option.
yep youre correct, my bad... to my eyes they dont seem to blue (while riding, im not concerned with what oncoming traffic sees)
as for the projection/brightness... well scatter or not, they show me significantly more of the road at night than the factory bulbs did, further projection was what i needed at night and these bulbs definitely improved over stock.... maybe its a visual trick, but within the closer range area they seem to illuminate better than stock as well.... at high speed on a dark highway the stock bulbs were dangerous (we have highways here that have areas with zero lighting)... i even tried aiming the stock bulbs higher than theyre supposed to be to get more distance but they just didnt have any power further out.... these ones give me the extra distance i wanted, especially with the brights on.
1 - 17 of 17 Posts
