I wired up my 55w 6000k's last night but the high-beam stays on. Would it be fixed if i removed the relay from the high or low beam or should i get a second relay for the high beam? I figure it has to be the high and low connected to the same relay thats causing the issue.
If i only use one relay should i hook it to the high or lowbeam? It's a gen2 bile
Sent from my iPhone using MO Free
