1 - 3 of 3 Posts
I am considering buying Annitori qs for my gen5 zx10r.. my question is has anyone had the opportunity To compare between tuning the oem shifter map thru race tools compared to purchasing annitori’s?
also,with annitori do u still have to tune it with racetools or it is sufficient with their app?
Thanx
I have an annitori on my gen3, its ok. But after running a Flash tune quick shifter on my gen 5 and r6 I would never use anything else. The up/down sensor is very compact robust and gives great feel in the shift toe. Cool thing about the flash tune as well is it plugs into the OEM connectors and just works right off the bat. If you want the autoblip you just need to have your tuner unlock it in the ecu via flash tune software. Good stuff.
Discussion Starter · #3 ·
Thanx for the reply tyler,
i have flash tuned my bike and have the autoblip unlocked it is fine.
I was just trying to compare how the annitori wolud run compared to a racetooled maped oem shifter
1 - 3 of 3 Posts
