These CE-certified motorcycle boots provides all-weather protection for year-round use. Bonded against the inside of the full grain leather outer shell is a Gore-Tex membrane that lets air move through freely while preventing water intrusion. The result is a boot that’s comfortable, not clammy and still waterproof. The boot is also armored, though you wouldn’t be one to tell from its outward appearance. Between the inner comfort liner and the outer shell in the shin, heel, toe and both sides of the ankle are high-density plastics that are designed to disperse impact energy should things go slightly wrong out on the road. For the sake of durability, both toes are covered on top with a polyurethane panel and the soles are made of a durable vulcanized rubber that’ll stand up to years of riding.
Further details can be found here or you can call TJ at 866.931.6644 ext 817 for more information. If you prefer email, send those to FORUM at RIDERSDISCOUNT dot COM with ALPINESTARS TECH TOURING BOOTS in the subject line and we’ll get back to you right away.
PU-covered toe areas to prevent wear on the leather when shifting.
Side-entry has a zipper and Velcro enclosure that’s smartly designed to prevent water intrusion.
One-piece sole is grippy in the wet.
