For Alpinestars CR, Alpinestars SP-1 and Alpinestars MX-1 leather suits, you know where to buy your Alpinestars gear - RidersDiscount.com! Every one of these suits come with a fully-removable mesh liner which makes getting into and out of, the suit a little easier. Each of these suits is fabricated from top-quality 1.2-1.4mm thick leather cowhide that has been developed with their years of experience at the top levels of racing. And along with strategically-placed foam armor around the suit, they all include CE-certified armor in the knees/shins, elbows and shoulders to give you a high degree of impact protection while allowing you to move about easily when you’re on the bike.
Mike is an expert leather suit fitter who can guide you through the sizing process and get you an Alpinestars suit that fits your particular shape. Long legs and torso? Alpinestars has a suit cut just for you. Always had a suit that’s tight in the chest but too long in the legs? Mike can tell you what will work perfectly for your needs. Call him at 866.931.6644 ext 804 or just send an email to MICHAEL at RIDERSDISCOUNT dot COM with ALPINESTARS SUIT CLOSEOUT in the subject line and he’ll get back to you right away.
Alpinestars MX-1 leather suit in red.
We also have these suits in blue and black.
Covering what has proven to be one of the most vulnerable joints in motorcycle leather suit construction, the shoulders of the MX-1 suit are covered in a high-modulus thermoplastic protector. This design reduces the amount of stress the seams over the shoulder would otherwise be expected to endure in a crash, significantly reducing the risk of seam separation and at the same time distributes impact energy over a larger area to reduce the likelihood of injury.
As an added bonus, these protectors also allow a high degree of ventilation in an area where it would otherwise be considered unsafe. Under the leather below this external armor, Alpinestars CE-certified GP protectors further aid in impact dispersion and absorption.
Specially-sewn leather accordion stretch panels are built into the suit behind the shoulders, at the lower back, above the kneecaps and just above the elbows allowing the rider a wide range of movement with no discomfort on or off the bike.
A large aerodynamic hump is fitted as standard. The hump is rendered with a hollowed-out internal foam liner to take advantage of the die-cut perforation at the top of it. In doing so, cool air is delivered straight to your back – providing much relief to the side of your body that spends most of its time getting baked by the sun when you’re on the bike.
Need a back protector? We also include an Alpinestars Bionic Race Back Protector with the MX-1 suit for free! The Alpinestars MX-1 includes a three-position snap fitting just below the collar which allows you to precisely place the back protector where it fits best. In this way, you always have your back protector with you, all you have to do is cinch the kidney belt in place before you zip it up and you’re ready to go!
