An old leather jacket is like a good friend: you get along great and you’re almost always on the same page - you stick together. The problem is, it might not be there when you really need it, like when you hit the ground after running over a pile of dirt in the road that was on the far side of a blind corner. Alpinestars’ Drift jacket has the feel of an old friend with the added benefit of having just graduated bodyguard school. High-quality 1.1mm full grain leather is used for the outer shell which has been distressed to safely give it a well-worn feel without weakening the integrity of the material. It’s well suited for abrasion resistance. Just under this, in the elbows and shoulders, fully-removable CE-certified Alpinestars Bio Armor is used to attenuate impact energy. In addition to the comfortably-positioned armor in the joints, PE-padded chest and back protectors have been added for full coverage protection.
Ventilation is provided with perforations under the armpits and by two zippered closures in front of the shoulders. On the inside, a removable vest liner can be stowed in the smallest of places when not in use. The neck and waist closures are lined with a soft microfiber material which is very comfortable against the skin. Plenty of pockets on the inside and out, permit more than enough storage for what would normally be found in your jeans and casual jacket. Overall, this motorcycle jacket is cut with a very relaxed fit, arms are sewn straight, making it comfortable around town when you’re away from the bike.
This particular motorcycle jacket is available in either a black vintage or chocolate finish in a wide range of fitted sizes. For more details on the Alpinestars drift jacket, visit our website and then call TJ at 866.931.6644 ext 817 for expert sizing advice and fast shipping. You can also email us with any questions you have, send those to FORUM at RIDERSDISCOUNT dot COM with ALPINESTARS DRIFT JACKET in the subject line and we’ll get back to you right away.
The chocolate/sand Alpinestars drift jacket.
Zip-closure intakes can be found in front of each shoulder.
Every zipper on this jacket has a leather tassel on its end for a retro look.
A removable vest liner is standard. Internal pocket arrangements are identical with, or without the thermal vest installed.
Microfiber-lined neck collar.
Also available in vintage black.
