First thing's first. It's an FI light, which stands for Fault Indication or Fault Indicating (or Fuel Injection as pointed out later. Pick your poison). It's NOT an "F1" light. :BangHead:
Secondly, the code(s) that is causing the indication can only be retrieved while the fault is active. The red LED and associated "FI" symbol on the LCD must be flashing for this procedure to work.
Here is the procedure for the 2021+ ZX-10R (Generation 6):
TBD
Early information states to press and hold the Mode and Reset buttons on the instrument cluster for a few seconds at the same time to show the service code.
Here is the procedure for the 2016-2020 ZX-10R (Generation 5):
---> NOTE: <---
Unlike the Gen 4, the system on the Gen 5 retains the codes for a longer amount of time until the system has gone through several ride cycles before automatically clearing the FI light and codes. In order to manually reset the system, follow the procedure below:
Here is the procedure for the 2011-2015 ZX-10R (Generation 4):
Here is the procedure for the 2006-2007 and 2008-2010 ZX-10R (Generation 2 and 3):
Here is the procedure for the 2004-2005 ZX-10R (Generation 1):
Once you have found the errors code or codes causing the light to come on, you can look up the actual problem in the service manual and go fix the problem. Without this number, there could be multiple issues with the bike ranging from minor (ie - exhaust servo motor) to something catastrophic (ie - crank position sensor, main throttle sensor, etc.) Don't take a guess! Pull the code and know your problem!
TBD
---> NOTE: <---
