1 - 6 of 6 Posts
Got the pipe on tight fit moved radiator out a little but still a bitch.Question is nuts that hold header on seem to not go on very far. Is this right?Thanks Roger
Yep, they won't tighten up flush to the top of the stud. Perfectly normal after having put a few Akrapovic full systems on these bikes a few times myself.
La Flama Blanca
THe clamp will cover the logo, but you can use your hanger, it looks like crap IMHO, and if you want to ride two up it only takes like 5 minutes to change back.
Thanks bro the website says hanger is mandatory,didn't know this I bought the system used with no hanger seems to be OK. probably will get hanger is position a lot different?Thanks for the help
1 - 6 of 6 Posts
