1 - 14 of 14 Posts
Can someone please confirm what is the lenght of the can on a akrapovic evoII hexagonal system. I think it's beetween 300mm(11.8")and 375mm(14.8") but would like someone to confirm. I suppose it's the same for the evoII oval if thats what you have but would prefer to have confirmation on the hexagonal.
The mesurement I want is for the can itself from the external of the metal holding clamp (part with the rivet) to the other side identical metal clamp.
Thank you!
inappropriate
youre in luck my hex slip on just came in the mail. measuring from the outside of the rivet clamps its just under 18 inches across.
Thank you but that lenght is for a standart lenght pipe. I am looking for the short version call evo II.
I have the same pipe as you but will cut it to the evoII lenght thats why I need this info.
inappropriate
of i see i plan on trimming 2.5'' off of mine which brings it to that size if not close.
351mm from outside of metal band to same on other end.
Thank you!
I am wondering if you have a pick of your evo2 carbon hexagonal pipe install on your bike as the only picks I seen are the titanium evo2 hex version on the 04-05 ZX-10R.
Discussion Starter #8
Your cut down canister has gotta be a lot more than 1 mm shorter than the actual EVO 2 can unless it's just the pic than makes it look that way. Are you measuring from riveted band to band or the whole canister? Yours looks like it's either 1/2 or 3/4 the size of the actual one.
Here is a pic
Discussion Starter #12
Your welcome,what are you doing?Going to make a evoII can?
Discussion Starter #14 (Edited)
Exactly.
Akrapovic are at 45-50% reduction right now because of a blowout sales going on but not on the hexagonal evoII were the reduction is a lot lower.
EvoII was 580$ more so I figure out that some rivets are not has expensive :thumbsup:
1 - 14 of 14 Posts
