1 - 2 of 2 Posts
Just got a mint carbon Akra can, but am missing the gasket (part P-G32). Before I take stock one off, does anyone know if can use the stock gasket at all?
Also with the valve, do most people connect it? I've read some of you haven't but they must of put it on there for a reason I guess.
You can re use the stock gasket which is thicker BUT you need to carefully take off a few layers with a knife to make it fit. I would contactt he seller and get the proper gasket if given the choice though.
1 - 2 of 2 Posts
