1 - 4 of 4 Posts
Hi all, I have a 2016 KRT 10r. I've read quite a few post about fitting blanking plates to the AIS system, but can't find info one what to do with the other lines. There is one attached to the intake flapper and another to the back of the throttle bodies. Do I blank these off, or leave them open?
Cheers - Bob
Block off plates typically come with rubber caps to close off all the openings left over when you remove all that stuff.
Discussion Starter · #3 ·
Unfortunately the kit only had the resistor plug and air box plug. No instructions either. 😖
The block off plates don't come with the nipples to block off the lines your remove from the canister to the throttle bodies. I purchased the kawasaki ones but you can also purchase them from an auto parts store. They are the typical ones used to seal vacuum ports.
You need 4 for the back of the throttle bodies(facing the rear of the bike) and one for the front. You need to block them.
1 - 4 of 4 Posts
