1 - 20 of 280 Posts
TRE is a waste of money if you drag race. I have not flashed my ECU nor do I plan too. I have a dyno tune on my PC5 with 87 pump gas, secondary flies OUT and my bike hauls a$$. I would give you recommendations for more power but I'm sure a lot of people on here wont agree with me so Ill leave it be at this point. BTW I street ride and drag race my gen 3 for almost 2 years now.
· Grease Monkey Bandit
Discussion Starter · #4 · (Edited)
First night at the track ran a 6.90 1/8th. I'll post the slip in a bit. First time launching and all, first pass was 8 something, shaved 1.2 or so thru the night...
I am 215lbs suited
Temp: 78
Rear tire: 190/50 shinko hook up 29psi
Passes were:
1-
2-
3-
4-
I was having a lot of trouble shifting into 3rd, clutch in, gas off and I would try to shift but it felt like the shifter wouldn't even move, had to let the rpm's come down before it would budge. Might have to get into the tranny. No problems in any other gears.
Sent from Motorcycle.com App
i wouldnt worry to much about addin more hp to the bike get used to the power you have now bc with the mods you have that bike is well capable of goin fast at the track just takes seat time to get there.
· BigCat for Prez!
yep extensions are JUNK. I had them for a good while and my 120lb wife used to ride all the time but the very 1st time she rode after i lowered it, they split.
Discussion Starter · #15 ·
So now here is the only problem I'm running into with going back to swb minus the fact I have none of the parts.
Sorry pic is dark... phone is almost dead and no flash. Grinded spot is where the brake caliper guide pin used to mount which is now grinded off.
· BigCat for Prez!
go to a metal shop and get a piece of aluminum the same size and have it welded onto the swingarm. If u know somebody with a portable welding machine itll be easier than pulling the swingarm off and bringing it somewhere, but im sure any machine shop can cut u a piece to fit
· BigCat for Prez!
The block should be 1inX.5inX.5in thats a guesstimate but will suffice as all it does is keeps the caliper from rotating when pads grip the disc
· BigCat for Prez!
1 - 20 of 280 Posts
