1 - 9 of 9 Posts
does any body know how to put an air shifter kit togather that would help or an link to one thanks
You surprisingly have several options . . .
I recommend getting the full kit from Muzzy although it is the most exepensive. The reason is because it is a full kit. You don't have to fabricate or buy a shift ram or bottle bracket from somewhere else. You don't have to run to Home Depot to get some fittings or hose.
Muzzy's Full Kit
http://muzzys.com/MZAS-K12/index.html
Muzzy's Shift Ram Bracket (included in full kit)
http://muzzys.com/air_shift_brackets/index.html
Muzzy's Electronic Shifter
http://muzzys.com/ZX10/ZX10ClutchlessShifter/index.html
Pingel's Sport Bike Air Shifter
http://www.pingelonline.com/super_kit.htm
MPS's Sport Bike Air Shifter
http://www.mpsracing.com/products/MPS/as02.asp
I would also recommend checking out Squatch Air Clutch Systems. They are more tailored to the KZ and GS world but you could still get a shift ram, air valve, and REALLY COOL air gauge/fill valve/shift button from them.
http://www.squatchairclutchsystems.com/
This should be enough to get you into trouble!
give us a call for the airshifter kit...we also offer a kit that is plug and play for the zx10 and most other late model sportbikes...no cutting or drilling required with our kit and i assure you that the kits we offer work since they aare designed and manufactured by dragracers for dragracers...803.285.8093
dwayne
thanks
thanks but I just got the mps the problem is no where to put the bottle lol:helmet:
You're welcome!
The problem with where to put the bottle is one of the reason I suggested the Muzzy kit. It comes with a bottle bracket to mount the bottle in the tail section of your bike. The bottle is sized to fit in your tail section. I had a Muzzy kit on my '01 ZX-9R for four years and the bottle, kill box, and regulator were all tucked away in my tail section.
im dieing for an air shifter ... i can only imagine the wheelies.
GeorgeC said:
What does an airshifter have to do with wheelies??? :dontknow:
lift it up in first and u can shift through all the gears without a problem. it might not make a difference for u or other ppl who can ride wheelies like animals. but i can ride a wheelie all through first, or lift it up in second and ride it all through second. but when it comes to shifting in the air, i cant
I'm no wheelie rider whatsoever... Don't know if the airshifter would be such a good idea for what you're describing, though.
1 - 9 of 9 Posts
