1 - 5 of 5 Posts
These air shifter kits are complete in all respects. They contain EVERYTHING you need to add "button" shifting to your ZX-10. Incorporating a high pressure gas bottle, you have up to 300 shifts between fills and that's at least 70 passes down the quarter mile.
Unlike other "kits" there is nothing else needed to install and use these kits. All wiring is contained in an OEM quality plug-in loom, and all components are of the highest quality. Your horn button becomes a selectable shift button that easily turns the system on or off and shift kill time is adjustable.
Installation is simple and well documented in the full color instructions and there is no drilling or machining required.
All mounting brackets are machined from billet aluminum, and all necessary hardware is included.
The gas bottle, which is mounted to the left passenger footpeg mount, can be filled with CO2, Nitrogen, or Nitrous Oxide at many locations such as welding stores or paint ball centers.
http://secure.cartsvr.net/catalogs/catalog.asp?prodid=3671411&showprevnext=1
$599.95
Does it fit with the fairings on?
Just looked a little big. :dontknow:
1 - 5 of 5 Posts
