1 - 13 of 13 Posts
i keep hearing about this but havent seen where it explains where it is? guessing its just allowing for more air flow.
I also need some plastics if anyone knows of any, I need left mid and lower, right lower, and tail. I dont want any missing tabs from the tail or anything
prolly the butterfly valve removal
Licensed Dist of HaterAde
IF it's this one then it's just a block off plate alt that gets rid of the popping on decal for the most part after installing a slipon or full system.go to pg 2 for the 1st gen and you simply unhook the tube from the airbox and put a plug in it and the inlet it went into in the airbox...works like a charm!!
http://www.zx-10r.net/forum/showthread.php?t=79926
you can cut the inside of the divider out in the ram air tubes. remove the 2 tall stacks in the middle and replace with the shorter outside stacks and pull the sec flies from the TB's.
just did this today, took out the ram air tubes, was like i am cuttin these out, removed butterflies, ordering short stacks this week along with a k&n or bmc filter
i only cut the "nose" part that extruded into the frame, kept the connector section from the airbox to the frame....makes a really agressive intake growl.
thought about doing this myself, but I did already cut out the divider in the snorkel. Did cutting the snorkel off make any difference ???
1 - 13 of 13 Posts
