Id love to find a black friday deal also. Haven't found anything yet.
So how much did you end up paying in usd? for gen5?Managed to get 15% off an MXK10 in the UK, but the offer's finished now.
It was £845 so about $1126So how much did you end up paying in usd? for gen5?
You have to use the Race Tools application.How do you put the shift light
Secuencial and then blinking?
Enviado desde mi POCO F2 Pro mediante Tapatalk
That's not something that is supported. The LEDs are ON or OFF if the threshold is met. There's no flashing feature.I konw the process. I just want it to flash all leds after that process ends
That's not something that is supported for this unit. It accepts PNG or JPG static images. It cannot display animated GIF or MP4 video files. You haven't seen any animated startup screens on the MXK10 because it can't do that. You've seen those animations on other instrument clusters that have that feature built in. That may be a feature they add in the future, but you'll have to wait.does anyone knows how to make an animated start up.. like I have seen.
I'm not sure what you're looking at for that, but I see no settings to flashing the shift lights. The options are for leaving each light on when above the threshold, or to turn a light off if the next higher one is triggered. Even running the simulation feature of RaceStudio to animate the settings never flashes them like you want. So, where are you seeing that exactly and have to verified it works in real-life?ok found it... when bike reaches desired rpm at the end of the leds it will flash..
you can mock the values and force them into the display and see how it does it
anyone noticed a bit higher idle???
From previous information I have on that, RaceTools overrides the OEM settings in the ECU firmware. You can't use both at the same time. If you are using RaceTools, those are your settings and you can forget about the OEM stuff. You can't pick and choose between them. It's all or nothing once RaceTools is checked and flashed.I have the racetools, and I DO NOT have the LC enabled...
and I cannot engage the LC oem by the life of me.... help
