So I finally got around to installing this. Everything went well until I tried to get the front cowl to drop forward. AIM missed a few bolt removals in their video. So I'll show them here.
Bolting the GPS mount is a real MF, as no room to turn them. I probably should have switched to allen head, and I will if I ever remove them for anything. You do not have to install the GPS, if you wont't use it for track.
It's hard to capture how clear the display is with your phone, but I'm real happy with that. So many features to explore. You can turn the Quickshift and Autoblip on and off independently of each other.
Once the GPS sync'd up it immediately found my track at Summit Point.
I do wish they would have let you change the ODO to match your bikes current ODO, and maybe they will in the future. I know there will be software updates to this.
This thing is built like a tank. It's heavier than the stock unit. All metal frame, and I think real glass on the display, not plastic.
