1 - 19 of 19 Posts
Discussion Starter · #4 ·
It looks better in real life.
The image is on my laptop and I have to go to work but I will chuck it on here if anyone wants it when I get home. I have a less "cluttered" Ninja ZX-10R I like as well
Premium Member
'16 ZX-10R KRT
I assume you just plug in the USB port and download any image you want?
Very cool dash...just waiting on Cyber Monday.
The dash connects via WiFi. You need a USB adapter with a 3-pin cannon plug on the back of it to use USB that AIM sells. You have to take the dash out to do that each time you use it that way or leave the cable plugged in and secured somehow. Not convenient, so USB is not the way to do it. The USB is really for the expansion hub to add more sensors.
Discussion Starter · #8 ·
Yes, very simple just connect to your AIM dash via it's WI-FI and transmit the image. Mine is a 2016 so just 1 R but it would be easy to make a RR version.
I assume it won't shrink the image on here but it should be 800x480 pixels.
Superbike racing Motorcycle racer Road racing Green Vehicle
Text Font Logo Brand Graphics
Premium Member
'16 ZX-10R KRT
The dashboard is really that easy, just plug and play? No programming required?
If one has aftermarket triple clamps, does the GPS module have to mount in that specific location?
There's no programming, it's just settings available. The GPS antenna can go anywhere within the 12in cable length that still has a good view of the sky. There's not many options for that. It would be better to drill and tap the triple clamp to mount it there. Otherwise, you'll just have to try and figure out where to put it with the cable.
Discussion Starter · #11 ·
It is plug and play, watch the AIM installation video on Youtube anyone can fit it themselves. You can select GPS speedo as well for 320km/h or changing rear tyre size you don't need a speedo healer gadget. Plus it is not just a dash it does data logging and has the ability to add modules to it for sensors on the bike, alot more than I can explain!!!
I have Woolich Autotune as well and I have flashed the ECU with the dash with zero issues. Bloody expensive but it is worth it.
If you swap out the triple, you will most likely lose the mounting spot for the gps module. I'm running the Bonamici triple clamp, and it does have a single mount under the clamp, but you would have to make a custom bracket. What I did though was relocate the gps module under the right side fairing where the charcoal canister used to be. Haven't had any signal problems at all and now it's tucked away and not visual.
I am thinking about getting this for my ZX10. Can you tell me if the display can change colors as far as the tach, speedometer goes? I saw a review about a year ago, that stated they were coming up with a firmware update. Just wanted to know this before I buy.
Premium Member
'16 ZX-10R KRT
No. There are only 2 color schemes. Day mode puts text on a brighter white background and night puts white text on a black background. There's no options for changing colors individually and it's not that adjustable/customizable. I run mine in night mode all the time because it's easier to see for me versus the white background.
Discussion Starter · #15 ·
I asked them the same question and they told me that is the plan in future updates. Not sure how long that means though....... month's or years?
I like how my Yamaha R1M tachometer changes colour as the revs rise (adjustable).
At least they have it planned to happen!
No no. Is it just the Kawi green? The numbers and what not. I know about day and night mode. Thanks!
Premium Member
'16 ZX-10R KRT
Well, since you already know about that day/night stuff, then let me reiterate the previous statement about "There's no options for changing colors individually and it's not that adjustable/customizable".
You get day mode with black text on a white background. Or you get night mode with white text on a black background.
446684
446685
1 - 19 of 19 Posts
