1 - 3 of 3 Posts
For the guys that have one. CH1 should be the water temp off a stock zx-10 sensor. There is a calculation in the Race software. When I am looking at the analog output of the stock pinout it is showing no voltage and therefore reading 266.:headshake
Does the stock sensor need to get some resistance aka temp before it will start to read temp and therefore put out voltage?
I have the Strada one on the 04. Be sure you got the right cable for your Pista (10 outputs i think?). They sent me the wrong cable and every reading went nuts.
When i switch my bike on i get a reading usually 25-30C depending on weather conditions. I found that it is not accurate, showing approx. +10C from normal.
1 - 3 of 3 Posts
