1 - 7 of 7 Posts
Italian made luxury good enough for The Doctor himself – the GP-Tech helmet from AGV ventilates much better than the Ti-Tech and doesn’t squeeze the ears quite as much either. The helmet is also AGV’s first to employ three different carbon/Kevlar shell sizes for a more perfect fit over their entire size range. An anti-microbial, fully removable liner is comfortably and is designed to work with the vents on the exterior of the helmet to keep your head cool in even the hottest weather. The visor mechanism is simply and easy to use too, don’t forget to order a smoked visor with this lid!
TJ has the knowledge to you get the right size helmet the first time, call him at 866-931-6644 ext 817. You can also email us at FORUM at RIDERSDISCOUNT dot COM with the size you want and we’ll get back to you right away.
The detailed graphics on this helmet take twice as long to lay out that most other GP-Tech paint schemes.
Don’t forget to order a dark visor so your helmet can look like this.
Great helmet! I own it and the Dreamtime and I think they're two of the most comfortable helmets I own. A little tough on the ears at first, but once the lid is on, it's super comfortable.
Blitzkrieg
i can dig it!
1 - 7 of 7 Posts
