The AFX FX-37DS line of helmets have become one of our top-selling models and we can see why; they’re unique, offer a lot of features common on more expensive helmets and meet DOT and ECE helmet safety standards. The FX-37DS is part of the latest breed of so-called dual-sport helmets that combine the utility of an offroad helmet with street-going amenities like a fully-removable liner and a flip-up faceshield. Although the peaked visor may make some think otherwise, the helmet is stable at speed and doesn’t unduly pull at your head. Ample ventilation is provided through a combination of nine intakes and exhausts which allow plenty of air to get in and efficiently leave while taking moisture and heat with it. The flip-up faceshield is interchangeable with a variety of tinted versions or if you wish, the helmet can be used without it in exchange for a set of goggles.
You can see the entire line of AFX FX-37DS helmets on our website and when you’re done browsing, get one by calling TJ at 866.931.6644 ext 817. You can also email us, send those to FORUM at RIDERSDISCOUNT dot COM with AFX FX37 in the subject line along with the size/color you want and we’ll back to you right away.
The FX-37DS’s faceshield is optically correct and UV-treated so you won’t end up with a weird sunburn on your face after a long day in the saddle.
Aerodynamic shell design is stable at speed.
Flip-up faceshield is easy to use and readily interchangeable.
Fully removable liner easily comes out and can be washed with soapy water. The fact that it’s made with hypo-allergenic/anti-microbial nylon means that it resists odors for longer than conventional liner fabrics reducing the frequency at which it will need to be cleaned.
The FX-37DS in solid flat black.
Flat Black Urban Camo AFX FX-37DS helmet.
