Hello everybody. I have 2004 zx10r. my 10r mods; PCV, ignition module, autotune, quick Shifter pod 300 display. i have problem with AFR mixture. on the same map AFR sometime is lean and sometime is rich and sometimes its correct mixture, this happens when throttle is open from 2% till 20% between 1200 4500 RPM. when the temperature of the motor to 80 is not very noticeable, but after 80 AFR starts playing between 11.0-19.0. first I changed ECU, same situation. after I changed whole throttle, calibrated throttle position sensor with power commander but no results, same situation again! I disconnect everything aftermarket parts but nothing changes! no FI light! today i started change main harness wiring. if the problem does not resolve what this can be?
please help me
