1 - 6 of 6 Posts
Got a full system Ti but the canister is damaged so I got another but the connection mid pipe and canister is not perfect like 1mm the canister is bigger.
So seal is not perfect
What should I use
Silicone hi temp?
Ac duct tape??
Any sugestions??
Enviado desde mi G3123 mediante Tapatalk
If you stop over to one of the car shops like Auto Zone, Pep Boys, NAPA...one of the auto supply places, they sell this crazy exhaust tape.
You buy this tape if your muffler has a hole in it. You cover the hole, let it get hot, and it seals well enough to pass a state inspection.
I believe this is the exact brand I used. Its cheap enough to be worth a try.
https://www.neweggbusiness.com/Prod...tC8_9FJezdzOkHoe5NhxVRQFBDFSdSrRoCNGcQAvD_BwE
Discussion Starter · #6 ·
Used hi temp silicone. The gap was 2 small to use anything else
1 - 6 of 6 Posts
