1 - 2 of 2 Posts
Ok im headed to the strip for the 2nd time in 12 months, last time did a 10.98 now in 1down one up and i have a qs, does any one have any reccomendations?
looking for tree advice and or bike setup to an extent
cheers in advance brothers and sisters
do you have the bike lowered any ? if not try lowering the rear and slide the forks up some threw the tripple trees to match the drop in the rear or strap the front end down when your at the track this helps ton keepin the front end down. good rpm to leave at swb is 5-6k focus on tryin havin the clutch out and be wot before you cross the tree. -1 +1 is pretty good gear to run im -1 +2 and she moves on out. good luck at the track and let us no how it goes.
1 - 2 of 2 Posts
