1 - 13 of 13 Posts
I changed my tire and now my ABS isn't working. It activates under slow speed and then defaults and the light stays on. Any ideas???
Did you reconnect the sensor?
Is this the front tire you changed? If so did you install the wheel backwards so the sensor ring is on the wrong side?
Discussion Starter · #4 ·
I don't feel like I did anything different than the first time I changed the sprocket. A little tight getting it back in...
Hmmm Check the wire to the sensor and make sure you didn't kink it or chaff it etc while installing the wheel.
Only thing that could be wrong is the air gap from the rear sencor to the abs ring but as you said you put all rear wheel spacers back the correct way!
Discussion Starter · #8 ·
Yes me to!!! If for some reason the gap was to big how would I fix that! There is not adjustment.. Should I try to tight the axle nut some more?
The Pace
Take it off and re-install. I suspect that you did NOT get the rear brake female part to match the little notch (the dick) in the frame. The female part is under the dick. Why the cable is tight. So sensor not lining up.
The Pace
You have two spacers, one on each side. Narrow on the right. Make sure both are there.
Discussion Starter · #13 ·
Update.... Remounted, reversed axle, spacers are proper... Shit still won't work. Looks like there may be a little wobble in the and ring... That might be it..
1 - 13 of 13 Posts
