Not bad, Is that from 93?
Yes from 93 octane.Not bad, Is that from 93?
I split the injector load on the top end so it doesn't push one set of injectors too hard. The pump seems to be handling it, we'll see. I have tuned a couple ZX14'S for E85 and I wasn't able to split the injector load but the injectors didn't seem to have an issue.How did you add the extra fuel? All on the top injectors? Fuel pump adequate?
Yep, that's my next step. I'm curious what the actual ethanol content is.Been running it for 2 seasons now on dragbike. It blows people's mind when you tell them it's on e85. Did you do an actual test to see how much ethanol was in it. Local summer blend here is about 90-91%.
