1 - 5 of 5 Posts
:dontknow: can i use a 530 chain with a 525 sprocket? or what about puting a RK with a DID both are 525's?
Yes, it can be done. You could also use 530 chain with 520 sprockets. :thumbsup:
So RR its ok to put the two different 525 together? Or is it safer to just use the 530 with the 525 sprocket. thanks man because i want to try out this new swing arm this weekend.{ RK WITH DID }
I would not suggest putting 2 chains together and especially on a stretched bike. Cause now you have 2 master links and they have been known to fail.
Just use the bigger chain with smaller sprockets for now. :thumbsup:
1 - 5 of 5 Posts
